Hi,
im hoping to make a false floor in my boot and was wondering how to attach the mdf to the boot floor or walls to stop it sliding an bumping around, or would i just need to make it a tight fit?
I used 18mm for the top and for the sides I used a long piece of pine which looked thick. I only used the pine on three sides as I figured you wouldnt see the rear side so no point!
Also I followed the line of the boot carpet around on the MDF but if you do that you'll see that it wont fit neatly into the corners so take a bit of time in measuring and so forth
