Dynamiqueee
Rite, hoping to get everything sorted by this Saturday. I have gertz comps to put in, mounting them to mdf baffles (mounted to the actual door).
Only thing left to do up front is sound deadening. Only I could find something so simple, so complicated lol. There are gaps in the door (outer skin and inner skin), is the aim to cover the whole door in deadening so there are no more gaps? (except for cables to come through ect) Or just deaden over the metal as it is, then do the same inside the gaps? If deadening over the whole door is the case, do i fill the gaps with anything? Or just stick the deadening over it?
2nd question.. The day i bought my car i wanted bass, so went out and spend too much money on a not very great sub & amp package:
http://www.halfords.com/webapp/wcs/..._productId_504839_langId_-1_categoryId_165702
Aparently the amp supplied with it is 'perfectly matched' however it is only 200 watts rms bridged and the sub is 400 watts rms? So im guessin if i get a more powerfull amp the sub will perform better? If this is the case, i'll be using the amp that it came with the power the comps in the front, and getting a new amp for the sub.
Found this - http://caraudiosecurity.com/shop/product/products_id/4250.html Would this suit the sub? Aparently it would be fine, but it seems a big jump from 200 watts to 420 watts.
However if i was wrong before and the amp i got with the sub is the one i should be using, then could anyone reccomend an amp for my componants., they are Hertz DSK 130. Sorry for the essay lol! and thanks in advance, Marcus
