Fault code P0136 question
Car  Clio 182
Hey guys. I've reset it but I'm wondering a few things.
I'm running a decat and have used one of those L shaped adaptors (screws into the decat and lambda screws into that). These are meant to try and fool the sensor. No light came on within 150 or so miles but then I got the clio 182 remapped to eliminate the chance of any light coming on in future.
Since then this code P0136 and light has came on. They said they wiped P0420 and this is different. Could it be that L shaped adaptor causing the light light to come on?
Appeciate the help as always.
For info P0136 is : O2 sensor circuit malfunction (Bank 1 sensor 2)
P0420 is The fault for a decat if P0420 catalyst efficiency below threshold bank 1 sensor 2. (This was meant to be wiped from ecu)
