fault codes and directions for were to look
  1.2 16v clio
Howdie people, basically I found these 3codeson my 03 1.2 clio dynamique using a cheap diagnostic machine
Df135 brake pedal circuit, signal incoherence, any idea were to look as google aint showed anythn
Df208 upstream sensor signal input, short circuit to +12v again no luck with google search
Df126 pedal potentiometer circuit track 2, short circuit to earth no luck searching this either
If anyone could tell me wear I could look to check these problems it would be a great help, thanks
  Mk4 Mondeo Estate
The main question is, is there any noticeable faults with the vehicle? By that I mean is there any symptoms of a fault that can be noticed without a cheap code reader? If the answer is no, then the faults are more than likely inactive and you'll be on a wild goose chase trying to trace a fault that isn't active.
  1.2 16v clio
Thanks for replying owen92 , everything seems fine with the car except its gone into limp mode twice, oncewhen I tried to drive up a car and was over revving and the second was when I was reversing up a hill caught the curb and over revved again, but I dunno if that matches the fault codes at all, thanks george
