Megane R26
Just need a bit of advice on my 182!
-Eml is on, diagnostics reads precat O2 sensor
-35 Mpg on long run compared to the 43+ I was getting in my 172 Cup
-Pulls hard to 5k rpm then becomes flat and strained. Noticeably dips in power
-idles fine, no spluttering or misfire
Is my front lambda sensor shagged? I thought it might be a blowing exhaust but that was welded up and sorted.
I am getting a slight whistling noise as the revs climb, just under full throttle.
Car is standard apart from cat back Scorpion exhaust.
