Fed up of the car pulling to the left
right
the time has come to get this sorted
ive had my car tracked loads of times and everytime i keep getting told the tracking is fine, but its still pulling to the left, seems the slower i go the harder it pulls? I think something else may be at fault but i have no idea what.
Does anyone know anywhere in south yorkshire where i can get the alignment checked properly and not by some greasy c**k weasel whos becon butty is getting cold everytime there checking my car.
Ph1 172 bye the way
FredYozzasport said:
shattered top mount bearing or snapped spring would make sense
i replaced the springs and it made it a little better
Kicking myself i didnt replace the top mounts at the same time because there rattling now. maybe there the source of the problem.
thanks for that.
Had same prob on saxo, after replacing both bottom track control arms, struts, springs+shocks, wheel bearings, droplinks, track rod ends, power steering fluid, 4 new tyres on reconditioned wheels and tweaking the strut brace I gave up! Only thing I did not try was looking for a bent anti roll bar. (readings said 1 degree more camber on off side-this was probably enough to push me over to the left - looking back on it I may have got a long/short bottom arm as they were pattern parts).
