feels slow
  clio 172 cup
Hi everyone had my car with renault for the last two weeks with a starting issue they fixed the issue but when it was there they put some petrol in it but only put cheap rubbish in it is have always used v power now I have got it back it feels really slow have now put v power back in it would this cause it to be slow because it will confused the ecu help needed
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
It shouldn't really effect it that much. Is it mapped? Was anything else done?
  clio 182 trophy
You can just about notice a difference in vpower to 95ron but it is hardly anything. Certainly not enough for you to think it was slow in comparison.
  clio 182 trophy
I can only just notice it am going to top it up with v power
Give it a good drive until the light comes on and give it half a tank of V. Should be fine then. Mine goes dodgy sometimes if i haven't been able to get momentum or v power.
  clio 172 cup
In which case if it was only that they actually touched then try decent fuel unless the somehow did a reset and deleted the map or something however unlikely?!
Is it still around £150 for a key?
Try 170 now mate yes gonna stick v power in a give it a blast tried bp ultimate really didn't like it
McGherkin
McPension
I thought my clio was down on power and unmapped.
Turns out it's actually quite a fast one and mapped.
It's a clio thing.
It could possibly be that they flashed the latest version of the standard map onto the ECU when connecting it to diagnostics, which I think is something they do, which if it was mapped beforehand would make it feel slower?
  clio 172 cup
It's a clio thing.
Oh ok I will put some v power in a see how it goes
It's a clio thing.
I can't decide if mine is mapped.. it revs to 7400-7500 rpm ish but still has a 5000 kick..
We need a little road test I think Callum.. would answer if we are both running ok I guess
lee M4RSH
mine hits the limiter at 7500rpm and is not mapped. I have plugged it into RS tuner and it shows the original ECU cal.
So I guess 7500rpm proves nothing.
