ANy decinet fluids fine to use loads of people have personal favourities mine the Castrol dot 4 super response £10 or so Demon tweeks is the only place I know thats seels it Halford sused to.
DS2500 pads will work fine on standard disks if you are thinking of going on track with your car i would recommend fitting braded hoses as for your brake fluid dot 4 and above should be fine if you do decide to fit braded hoses the best place for all your brake bits is www.yozzasport.co.uk if you speak to Fred or Andrew they are more than helpful and forth coming with any advice with your car .
Though I am aware that normal "race" fluid will absorb more moisture, and therefore boil and give air bubbles, as in normal race use, brakes would be bled before each outing.
I might be talking rubbish though
What I can say is that a freshly charged and bled system, running braided lines, Castrol DOT4 Super Response fluid, and Pagid Blue pads on Brembo GrpN disc will have you headbutting the windscreen all day long...even at Bedford.
Do a search for what BenR has to say about brake fluid to get a proper authorative answer.
