Few questions - help appreciated.
  RS clio 172
Just bought a 172 in good condition 78k miles ph2 2002.
My questions are:
1. a droning / whirring noise is occurring when above 55 mph from the front you can kinda feel it too, would this be the drive shaft / wheel bearing?
2. The front headlight is faded at the top, i've read on here something about a repair kit? do they work or is it better to buy a new headlight?
3. Where's the best place to source some cup/trophy wheels?
Any help appreciated! Thanks!
GrahamS
  335d
Search?
1) Droning could be a number of things. Does it increase with engine revs or is it related to speed? Does it happen when in gear?
2) Get a 3m kit, there are loads of reviews on here. One in the guides section and several thousand on youtube. 3m do a kit and so do meguires. It is also possible to use high grit paper as shown in a guide.
3) For sale section, you will need to get the correct offset. Sort the noise before you start making it look good. Its like a p**n star, can look great but it all broken underneath. That's no good.
  RS clio 172
Search?
Appreciate the time spent for the replies to all questions :)
1) I have popped the clutch down and also placed it in neutral when moving and the noise still stays, the noise starts around 30mph then gets very noticeable at 55-70mph a constant drone sound.
2) I'll have a closer look into the 3m kit then and give it a go thanks :)
3) Good point, i'll have it looked over at weekend by my workshop before spending any amount of money on the looks.
​Thanks :)
