Hey like it says on the label, Im getting my first renault sport tomorrow and was wondering if there is anything i should be aware of? like anything that is prone to go?
Ajcman have a search matey. I'm really not up to speed on the 197 but am aware of lower ball joints going. Standard things like checking if the belts have been done as they are expensive to fix.
If it's got recaros they are prone to wear on the bolster.
Gearboxes, belts/servicing, swivel hubs are the same as the 200s and meganes i think so check them. (If your driving the car and you turn the steering wheel, it should come back to the centre on its own, if it stays turned then they are faulty i believe.) Recaros.
Where are you getting it from mate? Down this way?
Yep, bottom swivels, best way to check them is with the wheel off the ground, but not easy when you view a car.
Track rod ends and inner track rods fail too. Make sure cambelt is done, aux belt not as important as it doesn't run next the the can belt on the 197. Make sure gearbox synchros work and there is no crunching. Handbrake cables stick, mainly driver's side. Check air con if fitted as they can slowly leak gas. Seat and steering wheels wear (not just recaro seats). All bargaining points!
Not getting it anymore, Traveled to Elgin three times for this car "being ready" phoned them twice before collecting it, allways saying it's ready and when i get there. it's not there the first time, the mechanic has to do a safety check the 2nd time and I can't remember why the 3rd time. NEVER buy from Arnold Clark Waste of time and money!
