Fitting 4-Point Harnesses
  LY200
hi there, got a clio 1.6 16v
got corba/sparco subframes and they have the hole in the side for what i assume are for the eye hooks.
where does the other side of the harness mount to? (door side)
also could i fit the backs of the harnesses to a rear strut brace? or will i need to weld some eye hooks in?
any info appreciated. cheeers
I think they would go into where the standard seatbelt mounts too.
Rear strut brace is dangerous for harnesses don't do it! Get some eyes screwed into the rear belt mount iirc.
i know they go into where the original pretensioner goes, but where does the other side go? also the back will be stripped out with a false floor. hope this helps
Where the standard belt mounts to at the bottom of the b pillar i think.
If it was me id just cover the floor with carpet so you can make a hole through to mount the eye bolts into the holes left by rear belts.
