as the title says, is this possible? Does the 0.6 make any real difference? I'm looking for some cheap wheels/tyres for my Jag but the choices are fairly limited, 5x120 is a BMW fitment so gives a few more possibilities
Wobble bolts would certainly do it, or depending on the offset you could just get bolt to hub adaptor spacers.
If using wobble bolts (they are a bodge whatever way you look but im guessing you arent trackdaying the jag) then you MUST use correctly fitting spigot ring adaptors.
