fitting alpine 9855r mrk2 phase1
hi, i have pluged it in but i cant get it to power on i have plugged in the red to each other and the yellow leads to each other and i have pluged in the two boxes with my boxes but there is no power with it i need urgent help what i have done wrong thanks!
have you get a multimeter???
if so you need to check to make sure you have power to the hu
something to use to check for voltage looks like this
have you tried to swap the red and yellow plug around on the hu wiring
You do know the hu only works with the ignition in the accessory position ?
Well at least it does with my mk2 ph2.
