Fitting Cobra subframe and Cobra Daytonas
MON
Car  titty cup'd 182
With the help of Ollie82. I (we) fitted the above to my car. The seats were base mounted (as opposed to side mounted) and the subframes were the normal (not x-low) cobra items.
The seats were 2nd hand and as I could not find any definitive thread on what hardware was needed to fit them I thought I would list what I used for future search purposes:
The runners were already attached to the subframe, but I decided to replace the nuts present with Nyloc nuts for security so 8 x M8 High Tensile Nyloc nuts were needed (4 per seat), a 13mm Spanner/socket is needed to secure them.
Attaching runners to seats: 8 x M8x20 High Tensile (12.9) allen head cap bolts (4 per seat). A 6mm hex/allen key is needed to secure them.
Subframe to car: 8 x M8x50 High Tensile (12.9) allen head cap bolts (4 per seat), with 8 x M8 High Tensile penny washers between the bolt head and subframe (4 per seat). We used the existing OE renault top hat nuts to secure them and 8 x M8 HT Nyloc nuts as well for extra security.
Seatbelt pretensioners to subframe: 2 x M10x30 HT Hex head bolts and 2 x M10 HT Nyloc nuts (1 per seat). A 17mm spanner AND socket are needed to secure them.
So if you have no hardware, you will need a minimum of:
8 x M8x20 HT Allen head cap bolts
8 x M8x50 HT Allen head cap bolts
8 x M8 HT penny washers
2 x M10 HT Nyloc Nuts
The 16 x M8 HT Nyloc nuts I used are optional.
Marc.
Nice little write up, should be made a sticky as this is a very common question asked.
