fitting exhaust
  Lunar Mk1 & Flamer
HELP!
what do i need to do? heard storys of peeple cutting their old zaust off to get new one on???
Got new centre section from cat back then a backboxsextion with a bendy pipe bit that looks like the old one do i need gromits sh*t like that?? howw long should it take?? bolt on bolt off or what??
  172 cup,s2 rs turbo
on an old clio rl its just a case of unbolting the exhaust and removing it.you will need to twist the back box as you remove it to get it past the rear axle(can be awkward but you will see what i mean).you will probably need new mounts and clamps.about an hour or so to remove and fit new one.
Get new clamps, bolts and hanging rubber things and new gaskets or a tub of exhaust paste! If youve got good access to the underneath of your car it will be easy, like a pit etc. you will struggle a little if your on your bak under the car. stiil quite easy thou. Learn from experience and all that.
