fitting harnesses
  1.4 clio rt
hi, im looking at getting some 3pt harnesses for my clio mk1, but does anyone know how they are fitted? any drilling needed? i see there are 2 points either side with some sort of bolt at each end, then one central point with like a clip? where does each part need to be fixed to? thanks guys, tom
the 2 points either side go each side of the subframe. hard to explain without pics, and the central one goes here, well...this is where iv put mine.
fitted with eye bolts in the fittings points supplied by renault. you can replace the renault bolts with eye bolts and keep the seat belts in at the same time
