fitting k tec top mounts.
Car  ph2 172
Right, so i have just bought some second hand, low miles K-tec solid top mounts and now want to get them fitted.
It will be a diy job so are there any do's and don'ts before it get the drill out?
Anyone got a pictured 'how too' for when they did there's?
​Cheers :)
Oh feck it! Looks like I bought something nobody has done before?
Oh we'll just have use our common sense. ;)
I'm pretty good with the spanners, but I had dan@519 fit mine.
Looked easy enough.
Just don't go wrong drilling the holes I suppose
Haha, yeah that's the worrying bit but gonna check check and double check again before doing anything.
Tbh it all looks pretty straight forward.
It does yeah. I just didn't fancy my chances of getting it wrong lol.
Good luck :)
Centre punch before you drill too. See Dan do it
Do I use the original bearing with the ktec kit or does the kit do away with it. Need an answer ASAP please as car is up in the air atm and need it tonight.
Cheers. As I said in an earlier post its using your common sense and we sussed it out. All fitted now only one bolt hole slightly out so had to work it with the drill bit to get bolt in but the car feels so much better and gone has that nasty rattling and clonking.
