fitting mirrors!
Car  Ph1 1.2
just bought some colour coded mirrors, but have no idea how to fit them!
can't find a guide on it as the search is so shocking..
any one know how??
ive tried that and nothing seems to be giving way.. I'm trying to remove the triangle piece from inside, yes?
first pull off the triangle piece on the inside , then you unscrew the black piece (2 torx) unclip the black cap hiding the first bolt, then loosen the 3 nuts holding the mirror on . fit the new ones in reverse. if you get stuck give me a shout.
i unscrewed the the bolt behind the black cap which is just off the triangle, and that screw didn't even fit the thread of the new mirrors. so i'm slightly confused..
i'll have another go tomorrow and see if i can change a mirror successfully :S
i need smaller bolts/studs :(
any ideas where i can get these from.
MOST FRUSTRATING f**king THING EVER,
I had the same problem as you, the screws etc were different on the mirrors and wouldnt secure properly, I ended up using big washers I think to secure them in properly.
