fitting my amp 2nite to my mk1. any tips?
Paddy_g46
any1 got a pic of the best place 2 get the power cable through? and also where shud i run the pre-out cables? right along the side of the car under the carpet?
mas
  MK7 GTD & Mini GP
for the power cable, in the passenger footwell if you look right up to the corner behind the fuse box there is a nice hole there to run the cable through, it will probably be plugged up with some sort of grommit... just pull it out.
i ran all of the cables down the passenger side underneath the plastice sill trim then underneath the carpet at the back of the passenger footwell.
its easy mate
Paddy_g46
^^^ wud i have to remove the sill and put it back on top of the cables or just push them up there
Pep
  M2,XJS,S1000RR
dont run you phono leads from the back of your head unit with any other cables.
you need to run the power and remote leads down one side of the car, and then the phono leads down the other side, otherwise this can distort your sound from the magnetic field given off by the power cable.
mas
  MK7 GTD & Mini GP
they are like popped on on clips, just pop the bottom ones, feed the cable up, and pop back on, easy
  mk1 RSi
yep make sure you run them down different sides of car
