Fitting outer cv boot
Car  172 cup
I need a new outer cv boot
Ive looked in the guide section but can't see one on how to fit a boot
Can anybody tell me all the steps required please?
Wheel off
brakes off
hub off
fitting cone on
lube it up
turn new boot inside out and slide it on over the shaft
turn boot back outside in
squeeze in grease and fit clips
refit hub, brakes and wheel
Simples
just unbolt the ball joint (do the 2 x 18mm bolts, not the pinch bolt) and you'll be able to pull the driveshaft out the hub, that way you don't touch the brakes or anything (you will have to put the steering on full lock, right hand down for passsenegr side removal, opposite for the other side)
