Fitting Recaro Problems
My Recaro seats finally arrived and went about fitting them following this guide http://www.cliomods.com/styling/fittingrecaros/
I have come across a problem though and wondering if I have been supplied the wrong parts or if I am doing somethign wrong.
The problem is with the positioning of the slide handle for moving the seat back and forward. The current Renault handle used on the standard seats fits fine but unfortunately it fouls the base cushion as said in the guide so would not be able to be pulled up. If
you see pictures below it should be more clear.
http://img89.imageshack.us/i/recaro1j.jpg/ Recaro with Original slide handle
http://img89.imageshack.us/i/recaro2.jpg/ Recaro with Original slide handle 2
http://img89.imageshack.us/i/recaro3.jpg/ Recaro with new slide handle
http://img89.imageshack.us/i/recaro4.jpg/ Recaro with new slide handle close up
http://img34.imageshack.us/i/recaro5.jpg/http://img89.imageshack.us/i/recaro5.jpg/ Recaro with new slide handle showing the other side fitted on correctly (right hand side)
http://img89.imageshack.us/i/recaro6.jpg/ Recaro with new slide handle marked up with yellow bits of paper to show where the bits should line up (middle of handle piece and middle of rail)
links don't work, use photobucket, imageshack is made of fail imo
Screwed up the links due to me rushing and can't edit now its been 15 mins. All working links-
http://img14.imageshack.us/i/recaro2p.jpg/ Recaro with Original slide handle 2
http://img13.imageshack.us/i/recaro3j.jpg/ Recaro with new slide handle
http://img525.imageshack.us/i/recaro4.jpg/http://img525.imageshack.us/i/recaro4.jpg/ Recaro with new slide handle close up
http://img34.imageshack.us/i/recaro5.jpg/http://img34.imageshack.us/i/recaro5.jpg/ Recaro with new slide handle showing the other side fitted on correctly (right hand side)
http://img22.imageshack.us/i/recaro6.jpg/http://img22.imageshack.us/i/recaro6.jpg/ Recaro with new slide handle marked up with yellow bits of paper to show where the bits should line up (middle of handle piece and middle of rail)
cant help you with your prob but here are the pictures to make it easier for others
http://img89.imageshack.us/img89/3991/recaro1j.jpg
