Fitting some AST top mounts and Eibach springs.. Advice needed
Car  Clio 182 FF cup'd
I'm fitting some eibach springs and AST top mounts tomorrow on my Clio 182 with Cup Pack, I just want to make sure i definatly won't need spring compressors, before I loose my hand? :p
Also am I best to leave the camber adjustment, unchanged until I get my tracking redone? Leaving the 3 AST bolts towards the front of the car isn't changing the castor/ camber right?
How oftern do the bolts on the suspension leg snap when trying to remove them? as I have no spares :( going to coat them in WD40 today to help prevent this happening.
for the cost of £30ish id get some spring compressors from your local halfords today.
if you dont need/use them you can take them back, but you dont want to get halfway through the job a realise you need them. i used them when i changed my sportlines but have read they people have done them without.
Mike, don't forget to jack both sides otherwise you'll be fighting the pre-load from the ARB. The 3xbolts positioned forward will tilt the strut back slightly and add a small amount of caster.
Three bolts towards the front is max caster iirc? thats how mines set up atm anyways...
You dont need spring compressors, Fred and I had my springs off no probs, and I just pushed the spring down while fred buzzed the nut back on.
