KitsonRis
Tried to search for this but couldn’t find anything.
Went to start the 172 yesterday after about two weeks not moving it. Battery was flat, but then for some reason I left the key in the cranking position for a few seconds after it had died, wasn’t cranking over, then it kicked into life. Then the immobiliser light was flashing like crazy while the engine is running. Engine was also running rough, but I thought flashing EML was injectors? Went to pull away and it stalled because it was firing on any number between 1-4 cylinders. Started up again fine and no flashing lights (but still ran crap).
Ive not seen the flashing immobiliser light once the engine is running, did it just get confused when battery was drained then kicked back into life? Want to rule out stuff for why it’s running rough (although think that is because it’s got damp in the recent rain and not been used) so I can get it sorted.
