flat spots on 182
Car  Ly meg R26
it happens in low and high revs and it wouldnt go over 60 the other day, its strange, any ideas?? cheers
maybe first lambda sensor.... when busted the engine goes in an "emergency run" and will not let you go the way your 182 is supposed to go ;)
Not sure as i'm no expert, when you get it hooked up to a computer at the stealers they should be able to tell sensor -problems. This reading out the comp. wo'nt cost you that much
