Flywheel position - F4R engine
  Renault laguna 2.0 T
Hi guys,
I just replaced a flywheel kit on my car, however there is no acceleration after the change. Can you please provide assistance or pictures if possible on the correct flywheel position when the piston engine is at top. The position of the flywheel is messed up, we lost the original alignment marking . we had the same issue with fitting the 5 speed gearbox at first but was resolved when placing the flywheel in its correct position. The original gearbox was automatic, I've put a clio gearbox.
Thanks.
kind regards,
Adil.
