Ok thanks, is the Gilmour Foamaster 2 any good?
i4detailing one is meant to be better and we get 7.5% club dsicount
http://www.i4detailing.co.uk/acatalog/HD_Snow_Foam_Lance_1L.html
^^^ Do what i do mate . First wash off any loose dirt with the pressure washer hooked up to the garden hose .Then i run a 6 foot length of hose into a 25 litre home brew fermenting bin filled with a couple of capfulls of Extreme body wash and wax shampoo and warm water . Then foam the car with high pressure foam , leave to dwell for a few minutes then continue with the 2 bucket method .
Hell of alot cheaper than these fancy foam lances![]()
MRBILLY -
Quick question:
As we're running the hose into the shampoo mix that means the water plus shampoo is going through the pump in the pressure washer doesn't it? Is that not bad for the pump?
None of the foam lances fit my pressure washer so if its not bad for the pump i'll be battering right into your method!
Cheers!
The amount of shampoo in the water is tiny , a couple of capfulls in 25 litres . You can actually use Karchers as pumps , for emptying things like fish ponds . As long as the pump is powerful enough inside the pressure washer you should have no problems using my method![]()
