Fog light /wiper issue
  • Thread starter Thread starter RyanWXM
  • Start date Start date
R
RyanWXM
I know the answer is bad earth but how do i solve this??​
1) When i brake/indicate and such acts the rear fog light flickers on the dash
2) When auto wipers turned on. When i put it into reverse it turn the rear wiper on (every time)
I've sprayed the light clutters with WD40 but still not help. Whens the earths that could be causing this and what is the best way to sort it ?
I think almost every clio has this problem... I have tried all the tricks in the book and mine still short every now and again, normally cleaning the earths fixes the problem, the earth lines run from the bodywork on the inside of the boot, take the plastic trim off where the boot lock hook is and fold back the carpets, you will see a wire running to a weld nut on below the retaining screw for each cluster, clean these up and it may sort your problem... on my clusters there is a short on the actual tracks in the cluster and not the earth... I'm trying to see if there are different clusters available otherwise I will probably end up pulling the thing apart and running proper wires to each bulb fitting...
