fred...
i know a lot of people wont see the point in this as its not going to be a particularly fast car but something different. everyone knows that the little dynamique is a fun car to drive so with a bit extra poke and a nice sound from under the bonnet and a rare mod(s) it would be something to be proud of.
So if there are any companies who would be up to building some one of parts/maybe a group buy let me know...
You'll have to go out find the companies it would be custom work.
fred, off the top of your head with a cooper s supercharger, what would be needed for 150bhp and the build/mounting etc?
would feel a bit better if the internals were strengthened for more boost but suppose custom work would be needed...
As Fred says you can get a secondhand engine and box for £100 off ebay, just stick a 50bhp shot of NOS on it and hope for the best!
50 shot will take out the engine unless correctly setup. Its been done before
reckon standard internals will run up to 150bhp and on what boost?
Its the rpm which is the killer of engines also you have to try control the det etc. there tricks they can do and run good fuel etc and water injection only way to be sure it to test it yourself I'd have stuck another head gasget on it though personaly at a minimum
Can you get a charger for ANY engine??
Yep. (within reason).
Whats within reason then??
if your talking 1cc engine or silly thing its not exactly of the shelf bits.
Rotax do a range of superchargers also you can find there lim ited boost wise so you migh need to run two if you want to run silly boost numbers.
