Friends Dream Car
Rojer
Congratulations to my friend who recently purchased his dream car an Evo 7! Couldn't be happier for him! Today it came back from Norris Designs where it had a Link ECU fitted and mapping. It made just shy of 400bhp on low boost and 500bhp on higher boost. The car is mint and im very jealous!!
Here are the specs.
Engine
2.0l long rod Engine - built by Damico Race Engines.
Standard bore Evo 7 block striped and acid dipped.
Line bored to take the new ARP studs
Balance shaft oil gallery’s tapped out and plugged for extra tight oil seal.
Re-honed, As it didn’t need a re-bore.
New core plugs
New sump pan
New oil squirters and banjo bolts
New Mitsubishi oil pump
New oil strainer
New water pump
Cometic 1.2 mm head gasket
Genuine gasket kit
Cam and crank seals
Rear main seal
Weisco 85mm 1400 hd stroker pistons
156mm Carrillo long rods
ACL Race Bearings
ACL thrust bearings
ARP head Studs
ARP main studs
New Mitsubishi Balanced and lightened Crank
Tomei Oil Baffle plate
Brian Crowner Titanium Valve Springs & Retainers
3mm Lash Adjusters.
GT 262 cams
Genuine HKS Cam Pulleys
Gates Racing Cam Belt
Zaklee upper cam belt cover
New Hydraulic tensioner
New genuine cam belt idler and tensioner pulleys
Balance Shaft Delete
New cam shaft and crankshaft sensors
New temperature sensors
New water pump pulley (these are known to crack so was replaced)
Polished alternator
Evo 6 rocker cover with AN -10 fittings
Neverman stealth catch can
Cylinder head striped down and acid cleaned. valve guides checked and valves re-ground into seats new valve stem seals fitted.
Fuel system
Neverman fuel pump hardwire kit with tyco electronic micro relay
Aeromotive 340 lph fuel pump
ID1000 Fuel Injectors
AEM Fuel Rail
AEM Fuel Regulator
Russel sports pressure gauge
Turbo
Ross Sport HPB IX ball bearing turbo.
New oil feed and return lines.
Air intake and charge cooling
Massive OBX Intercooler
Intercooler hard Pipes
Ross Sport 3” Hard pipe Intake
K&N air filter
APS Dump valve.
HKS silicone pipe connectors
Custom sfs lower boost pipe
HKS J pipe
Exhaust system
JMF high flow manifold
Invidia 3” turbo elbow
M2 motorsport 3” front pipe
Russ fellows custom 3” decat back exhaust system
Oil and oil cooling
Run in using Joe Gibbs Driven break in oil Only run on Driven Racing oil.
No limit motorsport 19 Row Oil Cooler.
Boost control and engine management
HKS EVC 6 Boost Controller
Apexi D Jetro ECU with hand controller
Speed Density Conversion
Coil on plug kit with denso coil packs
LINK ECU
Mapped at Norris Designs
Engine cooling
Brand new water pump
SFS Silicone Water hoses
Large aluminium radiator
ARC pressure cap.
Drivetrain
Re-conditioned 5 Speed gearbox (stronger and better ratios) rebuilt by Suffolk transmissions.
Neverman selector cable solid bush conversion
ACT organic clutch
Racing flywheel lightened
Brand new Slave cylinder
Refurbished AYC with braided lines and steel pump plate. (Done before I got the car)
Tein Coilovers with electronic damping control (EDFC)
Front Cusco Strut Brace
Carbon fibre rear strut brace
Brembos (repainted and new dust covers) & Hawk CF Pads
Braided brake lines
Polly bushed anti roll bar bushes
Rota's 18 x 9.5 & 245
Interior
HKS turbo timer
Evo 9 Ralliart Half Leather Seats Front & Rear
Evo 9 Black Carpet
Evo 9 Dash Inserts
Ralliart Floor Mats
Ralliart boot carpet
Carbon Gear Surround
Ralliart Gear Nob
JL Front and rear Components
2 gauge pillar pod
Defi oil temperature and pressure Gauges
Tinted Windows
Bodywork
Carbon Front Wings + 20mm, Custom Painted
Evo 9 replica Rear Bumper with Carbon Extension
Carbon 7 bonnet
Carbon Side-Skirt Extensions
Varis Carbon Front Splitter
Carbon Rear Spoiler (bit faded)
Carbon rear bumper extensions.
US rear lights.
Engine bay
Stainless slam panel cover
Stainless Spec r power steering resivour
Stainless spec r engine coolant resivour
Neverman catch can
Rojer
Wheels will be changed for something better and Japanese. I personally like the carbon. Looks lovely in real life.
Euan94
  Volvo C30
Was just about to mention, how can you spend that much on a car and then still fit Rotas. Would love an Evo though, not too my tastes but fair play I bet it’s amazing
Ant1
Brembo! Brembo! Brembo!
Oh I do miss my Evos, I like all the foundation work done on that but can’t stand the exterior, however if he’s happy fair play ??
Rojer
I'll just mention that he bought the car like that. However I think he is pretty happy with the spec apart from wheels.
Rojer
or paint the CF panels? Rear lights look horrible as well.
Lights are US spec. Well each to their own I guess. I'm just happy that he got his dream car and it goes very well. Built to a high standard. Exterior can be changed if he wanted.
Matt Cup
  Leon Cupra
Huge list of mods, I was scrolling down wondering when the pics would show up.
Reminds me of Marty's Evo off Mighty Car Mods.
imprezaworks
  Mk5 Golf GTI :)
Had an immaculate 53 XT330 7 A good few years. Was an amazing car.
This was back when a clutch was 1k in cash. Had it mapped by a guy in Warrington iirc, went very well indeed.
