front 02 sensor error code?
bob the builder
Car  clio 182
hi can anyone help.
my eml keeps coming on, it says front 02 sensor. df0092 and df0967.
does anyone know what these are or is it just a case of fitting a new o2 sensor?
the car seems to run and drive fine just smells a bit fueley from cold.
cheers for any help
rob
Sounds like it might be the lambda sensor before the cat if it's a bit fuelley when cold. Before spending any money try swapping the lambda sensors around as the one after the cat is normally a lot cleaner and has more life in it. They're exactly the same. You'll need to get the car on some axle stands and a 22mm spanner iirc. Takes about 15mins once the cars up. It might sort it. If not then all you've lost is a bit of time. GSF is usually the cheapest place to get a Bosch lambda sensor. About £90 when I checked at Xmas time when my EML light came on. Cheers
