Front ABS Rings
welshname
Afternoon,
Got a cracked ABS ring causing the ABS to be a little bit funky under low pressure, low speed braking.
Off to the 'ring next week and should probably fix it before I go. I've found them on GSF and was told by Feirny that ECP do them, but can't see them on ECP's website.
Anyone know where is best for just a single FRONT ABS ring. Believe they should 44 teeth.
Cheers.
They cost a tenner plus postage and you need the 44 teeth version for all the 172/182s. They're easy to fit as long as you can get the hub nut off and I found it was best to start to remove the old one before removing the drive shaft etc.
I ordered mine from here, fits and works perfect.
http://www.ukpartsdirect.com/abs-reluctor-ring-428.html
Not sure on how many teeth you need, I know it was 44 on my 182 FF, may be different on a 172.
Ignore this bit though.
