Calling Loony/Fred here!
Finally got my front bits through from Ktec at the start of the week and had a go at fitting them yesterday as I had the day off. I fitted one side but it doesn't seem right to me.
I held the new shock up through the bonnet and spun the top cap on a bit to hold it in place, then did up the two bolts on the bottom. Lowered it down and tightened the top cap up.
But when I came to tighten the top nut under the bonnet it doesn't tighten up properly for some reason. The thread doesn't stick out very far in the bonnet (compared to the original) even with the car lowered back down, and the nut just spins the piston/rod in the new shock even by hand it spins that freely.
I'm wondering if I've assembled the top right. I put it in exactly as it came in the box:
The lower nut on top of the 'tin hat' has been tightened down as much as possible, and the large original Renault donut shaped 'rubber stop' is sitting on top of that immediately in contact with the chassis hole.
There isn't even enough room to put the very top nut in the picture on the top of the thread once the top cap is spun back on, as like I said the thread doesn't come through the cap very far. Probably 5mm thread visible. Plus the top cap just spins by hand with the shock's piston spinning as well.
Where have I gone wrong?!!
