Front drivers brake getting stuck on!
  Clio 172
The front drivers brake on my clio is getting stuck on. Its not enough to stop the car moving but you can feel resistance and the wheel is getting very hot. You cant touch the disc on that side but can the passenger side so its that one thats getting stuck.
Can these just be taken apart and greased cleaned etc?
  Megane r26
Strip it down an makesure all sliders are free an then try an push the piston back in with a set of large grips, more then likely seized piston in the caliper but you never know.
Not sure if a rebuilt kit is available but if it is it can save you a few quid.
  Megane r26
Its important these are kept greased to keep the braking performance optimum. I had it on my old 172, made it terrible under hard braking real nasty pull as the effort isn't equal.
Glad it turned out to be a slider though, nice cheap fix ;)
