Front strut brace adjustment
  clio cup 172
Hi all,about too fit omp adj frt brace,does it push out on strut tops or pull in? If you know what i mean;) also what size bolts will i need?
bozothenutter
if anything pull in, that would (potentially) give a little bit more camber.
though I understand no more than 10Nm should be applied.
if it is already mounted you don't need any bolts, if you are gonna put tension on them, the biggest that will fit the hole I guess!
