Ah ok, a mistake some people make is only having one wheel off the ground which means the ARB pulls the arm up on the other side.
Tip the hub outwards, get one bolt through, then push back straight to get the other one in, dont worry about trying to line both up at once.
And if you still struggle put a large screwdriver through one hole in the hub and shock and use it to centralise the other one to allow you to get a bolt through then replace the screwdriver with a bolt in the first hole once the second bolt is through.
They should be fitted bolt head to the front and nut to the back if you want best practice (so if the nut comes off the bolt is still less likely to fall right out)
