Just wanted to deliver a word or warning. Don’t have your drive splines zinc coated, there is just enough factory clearance to suit Renault OE wheels bearings. Once you coat, there is inadequate clearance unfortunately. Which I learnt on the rear splines. Had to revert back to unzinced splines which luckily I had spare.
Pic below shows what happened when I tried to mount an OE Renault rear disc which pressed in SKF bearings as delivered from Renault.
Those surfaces are usually hardened finish from the factory and should never be plated. Even if there was clearance.
Wrap them in tape and plate the rest.
Sent from my iPad using Tapatalk
