Front Wheel Screaching!
Car  Meg 230 R26 F1
Can anyone shed any light on a possible cause for a whine that comes from the front drivers side wheel on my ph1.
Its a frequent whine that lasts for around 10 seconds then disappears but is usually back every minute or so. It sometimes disappears when i go round a corner or turn the wheel, not always though.
Its not the same as a brake squeel as i get that too.
Thanks for any info
Have a look at the tyres and wheel arches to see iff one is rubbing the other, if that seems ok then it will be the wheel bearing.
Cheers, definitely not the tyre or wheel arch.
Apologies for lack of mechanical knowledge, but is the wheel bearing fix a quick and easy job, or are we looking at big £££'s?
N o not big £££££'s, you should be able to diy if you have some tools. Hopefully a friend will assist who's done this job before. Probably best to do both sides at the same time as it's hard to diagnose which side is the culprit. At a guess it will be the nearside bearing as this takes the most punishment from kerbs/potholes/drains.
Just done another search on here, and all faulty bearings are making a droning noise? Mine is definitely not a drone but a high pitch whine. Still bearing?
Car has started making a rumbling noise on acceleration too, coincidently after going through a nasty pothole.
Could also be a CV joint then. Best to have it diagnosed by a decent garage. Hope it' not too expensive for you.
The whine has progressed to a quiet metallic scrubbing noise. Still bearing?
In anyones opinion, is this safe to drive on as i have no time to get to a garage this week?
