Front wheels rubbing on arches... 20mm above max ride height already!
  Clio 172 Cup Mondial
I have had problems with my front wheels rubbing on the arches when cornering.
I have KW's V2s currently 20mm above there max ride height. Which means it's only lowered 20mm.
Have solid top mounts with these which I guess take the ride down another few mm.
I am running 205/45 r16s but surely they aren't that different over the 195s??
Here is some photos. When I turn wheels go really close to front arches on both sides.
Any advice would be appreciated. All I can find is rear wheel rubbing on arches.
Thanks in advance.
Photo 2 is drivers side and 3 is passenger side at front of arch. If I turned to left then drivers side would have been just as close.
Thanks for the prompt responses.
I don't think it has spacers unless a previous owner put them on.
Here is a photo behind wheel arch. Is there a spacer here?
Yer unless the instructions with my coilovers are wrong about heights. It says have a 120-150mm space between top strut bolt and bottom of spring and I have 170mm.
Yer I was looking at cutting away with a dremel but didn't know you could actually modify the bracket.
Ok thanks.... Could it be something that could change due to wear/tear.
On a different note... Look what I found in my arch...
Hahahahaha
