Fuel and starting issue
  Clio 172 phase 1
Hi
Very new to the Forum but in need of some advice,
i have a phase 1 172 that has been stored for a year, it has always started first time. I have come to get it out for use this year and it has decided not to start. At first the fuel pump was priming but was just turning over without firing. Now i seem to have lost power to the fuel pump all together. Reading some of the threads on here i have tried to sort the issue but with no joy. As it stands i have checked all fuses and contacts, checked the relay under the bonnet which i think are for the pump (if someone knows or has a diagram for this it would be appreciated just to make 100% ) but still no pump prime on ignition, the start up lights sequence seems to be right and if i put a direct 12v down from the cut of switch located at the battery the pump runs.( I don’t have 12v at the cut off without a direct link).i have checked and tightened the battery terminals and the engine earth.
Any help on this would be appreciated
thanks
