It's built into the lift pumpLooking for the fuel filter on a Renault megane 225 Please![]()
Thankyou, will let you know how I get onIt's built into the lift pump
Thankyou, will let you know how I get onAs above filter is internal in fuel pump sender on uk spec, no separate filter and you cannot change the filter fitted to sender. Fuel pump/sender unit is 70k service interval iirc.
It's just a tea bag style filter that sits over the inlet side, I assume there's some aftermarket ones available that you can swap it out?Thankyou, will let you know how I get onJo
You will need to change the full fuel pump assembly if your doing it. Well worth doing now the mileage/age is getting up there on mk2 rs.Thankyou, will let you know how I get onJo
I was just looking at some forums as it won’t rev above 3000 & someone said to check the fuel filterYou will need to change the full fuel pump assembly if your doing it. Well worth doing now the mileage/age is getting up there on mk2 rs.
I was looking at some forums as it won’t rev about 3000 & someone said to check the fuel filter, the fault code is DF054It's just a tea bag style filter that sits over the inlet side, I assume there's some aftermarket ones available that you can swap it out?
I've never heard of anyone replacing them though tbh (doesn't mean it shouldnt be done of course!)
It’s coming up with a fault code of DF054I was just looking at some forums as it won’t rev above 3000 & someone said to check the fuel filter![]()
That is the turbo solenoid valve (have another Google)I was looking at some forums as it won’t rev about 3000 & someone said to check the fuel filter, the fault code is DF054![]()
