You can check if it's the bulb by using the diagnostic check. Depending on your model you either hold down the trip reset button on the dials or hold down your right indicator stalk while you turn the ignition on. If you hold down which is correct for your model you'll get all the lights around the dials come up so you can see the bulbs are all working.
