fuel pump change valver
hey all how easy is it to change fuel pump on a valver? can it be done by taking the back seat off and pulling it out? also any 1 know where i can get a chaep oone in west yorkshire? Cheers
We all know how to change fuel filters but im not sure about the pumps mate!! - i think it may be quite a tough job. It is definately in the Haynes manual tho and worth a pop!
  Mr2 Roadster
Should just unscrew the cover and then unscrew it, disconnect it and pull it out... Cant be hard, just go easy on the fags!
  (ex-2.0 Hybrid)CorradoVR6
Theres two tyres, one you can just remove from under the back seat, the other earlier one is inside the tank.
A tyre inside the fuel tank? LOL!
  172 cup,s2 rs turbo
pull up the rear seat. if there is only one inspection hole then you will need to remove the fuel tank. when you get to it anyway its removed by unscrewing the large plastic retaining nut.
