fuel pump question...
Car  200bhp itb'd iceberg
have a query for you :D
Where is the fuel pump on a t reg 1.2 clio rn?
my car has a 172 conversion but think it still has 1.2 tank and pump... because when fuel level gets low (like 1 mark on the fuel guage) and i go round a round about its like its starved of fuel like missfires and cuts out then it will go again fine,
do you think uprating the fuel pump to a 172 pump will make it better?
has any one uprated there fuel pump?
just found some walbro pumps on ebay
but dont really wana buy one to be honest just want some advice
thanks
jono
its under the rear seat, on the drivers side.
there is a small black cover, pull it off and you will see the top of the tank and pump
erm, possibly, it will have a part number on the top maybe...
if it does not, unscrew the big black locking ring, and disconnect the plug, carefully lift it up out of the tank, there is bound to be a part number somewhere on there
if its the same thing the mk1's suffer from starvation under hard cornering (normally the cup racers when running slicks)
people have looked into using tank foam or similar but not sure if anyone has cured it yet
