Fuel Pump Relay
Car  ph1 172... Sold:(
Does anyone know where the Fuel Pump Relay is located on a phquick?
My car has an intermittent starting problem that has not been cured by replacing the TDC sensor.
Starter motor and battery are strong, once the car has started it runs fine. It doesn't cough or splutter; it just doesnt start, then after several (pick a number) attempts it does. There is no smell of unburnt fuel when it does finally catch.
I was thinking I'd have a look at the condition of the contacts on the fuel pump relay, but where does it hide?
S.
hi ya, iv got exactly the same problem with mine, its happend three times now in two weeks, if you find out the problem can you post it on here and ill do the same whe i find out, cheers!
