Fuel rail guard
Car  turbo 182
The 2 10mm nuts are both rounded that hold the fuel rail guard on. :( any idea how I can get them off? There is next to no room either. Thanks
Buy 2 sacrificial socket bits one size smaller than the nuts and hammer them on so they bite into the metal,
then buy 2 new nuts.
I've tried 6 and 12 sided, still won't grip, there isn't enough room to hammer sockets onto the nuts either..... Or is there? Thanks
May have to remove the bumper to get a swing with the hammer, bit of a pain but not a massive job.
Hit fuel rail guard with a hammer and shatter it, then buy new one for £5
So hit a bit of cast metal that was specifically designed to take a blunt impact and resist such impacts then in doing so risk breaking the lower inlet plenum/plastic fuel rail or worse (and slightly extreme), rip the M6 grade 8.8 studs out of the head? Yeah, I wouldn't do that.
i think the easiest option is to grind the fuel rail cover off. unless some1 has actually managed to remove the rounded nuts before?
They are made to take a front impact, not one from the top ;)
The support ribs below suggests otherwise Danny... but I'm up for watching someone that one.
