Turd Pocket
Cumpact
Hi Folks,
Im after a bit of help. My car was throwing a misfire code and flashing the EML every so often. The idle was fine and it drove fine but obviously I didnt fancy an injector failing on me in the middle of nowhere. So, I bought a second hand fuel rail with injectors from a working car and fitted it. Everything went smoothly except the fuel line fitting to the rail had split one of its rubber o-rings. Anyhow, Im going to buy a replacement o ring and fit that but test drove the car gently after checking there were no fuel leaks. Test drive went perfectly and so parked the car up. When I went back to move it about 15 mins later the car wasnt starting and was acting like it had low battery. I had removed the battery prior to the rail change to fit a new wheel so could it be that the battery (which isnt great anyway) is throwing a wobbly? Unforutnately I didnt have time to test any of this yesterday but I wanted to rack all your brains before diving in.
Thanks in advance
Thanks in advance
