Fuel return line
Car  RB 182 Cup
Hi just after a bit of advice.
I need to set up a fuel return line in my 172 Cup. I understand the ph1 came with a fuel return line so i would like to know what i need to make it work on the ph2.
Any ideas where to get the parts from?
Phase 1 rail with regulator and in tank pump from a phase 1, along with the fuel line.
May I ask why you need to?
Pump, Rail and the actual return line from a Ph1 172. Some of the later ones were in tank reg though so be careful.
I have brought an uprated fuel pump and i have the ph1 rail with regulator. Do you know where i can get the fuel line from? Also the ph2 does not look to be able to recieve a return line, so will i also need the sender unit from a ph1?
I am currently building a forged Supercharged shed.
Would this fit the 172 cup? Also is this the sender unit with a return valve as it has two nozzles?
