hi guys ive got a 1.2 16v clio on 04 reg but didnt come with manual so im looking for fuse box location cause i dont have a handbrake warning light on dash so i ve checked the plug and that seems fine so im thinking it may b a fuse or something cheers
I'm not 100% sure if your mk2 ph2 is the same as the mk2 ph1, but open your passenger door and then on the side end of your dashboard there should be a fuse box cover, pull that off and your away. It has fuse diagrams on the otherside of the fuse box cover.
^^ i would imagine its part of the stop fuse but not sure. Just look if any of the fuses are blown cause really none of them should be unless ur not bothered bout certain things not working.
And seein as ur only in blackburn keep an eye out for local meets and come down. Had one in preston last week and one in manchester last week.
