Gear change on a 172 Cup
  Peddled device
Anyone had any problems with the gear change being a bit notchy on a Cup?
[Edited by RALLYPUG on 09 August 2005 at 8:39am]
  Nippy white cup
Probably the box on its way out m8y...usually I think its 3rd that goes but not sure. Mine sometimes grinds into third are high revs (you cant change quickly either) and sometimes 4th when you are just pottering around town.
Chris
EVOgone
  Pink Cup Racer
Get a K-tec bottom engine mount and a B&M Quickshift for the best solution.
Ultimately the box is crap so rush gearchanges are hit and miss plus its a bit fragile.
  cock mobile.
Mine sometimes needs a damn good push to get into third, especially when changing down.
Do you think I could get that changed under warranty if I was to moan at my dealer or would they more than likely tell me to bugger off!
The warranty runs out in march.
  Nippy white cup
Id take it in m8...just tell them whats up but play a little dumb...they might sort it for you
Chris
  cock mobile.
Yer gotta be worth a shot, want to get something out of this warranty!! Cheers mate.
  cock mobile.
Ive booked mine in next Thursday for a check over, will let you guys know what the outcome is!!
Sh33n,
What was the outcome with the gearbox problem? I have the same problem with my gearbox changing down into 3rd and my car is still under warranty.
Wow, I have the same problem - find 3rd sometimes grinds when you are changing quick. It seems it is a common problem for Clio. BTW, i have the B&M short shift too.
Really want to know if others Clio has sticky gear changing problem when in hot weather and after a while of driving, like 20mins.
  RS-1, Bebop, CTR
Chris
i have the same problem in third...its really quite unpredictable, but it usually happens when im shifting over 4000 rpm from 4th down to third...can be very annoying at times...
what did you mean by "box on the way out"?...i was considering to have that fixed, but if its not a potentialy serious problem, i would prefer the gearbox not being tampered with...
  172 Cup
Mine used to, must of got used to it. Think i just hold the clutch down an incy bit longer between 2nd and 3rd.
If Im a bit too quick going from 1st to 2nd itll grind like hell! Cue much embarrasment and having to start the gear change again :oops:. I probably just need to lift off a bit more :(
[Edited by d_182 on 17 August 2005 at 1:59pm]
i got 60,000 miles out of the standard box with no issues at all. you have to be agressive with the change in my experience. The short shift seems to be the biggest problem on the 172s, people who have them, have gearbox problems. I find the standard stick more than adequate...
/y0z
  cock mobile.
Just got back from my dealer, and to clarify my car is completely standard, apart from the ITG Panel Filter.
Anyway, they actaully acknowledged there is a problem, which I was shocked by, thought I would be in for an arguement! They said they now need to contact Renault UK and find out if its cheaper to change the whole box or fix the current problem. Didnt even realise that could happen, but I should hear back by Monday so will update all those with this problem then!
I took my car in on tuesday and mentioned the following problems
the car was hard to change from 4th to 3rd and from 3rd to 2nd
The car makes a wobbly knock when doing a u turn then accelerating
my passenger seat latch is faulty
outcome
car needs a new gearbox - which will be done under warranty
wobbly knock is a common problem and reno has a fix which they will install for free
seat will be sorted - under warranty
not happy about gearbox going when its only done 30k and i dont rag it (much) but glad problem has been found and it isnt costing me :)
Car will be going in this tuesday coming and hopefully thats the last problem i will have for a while.
  Nippy white cup
I took mine in and it is currently getting the new box fitted. I have the quickshift on and TBH I think Ill get shut....it is a good gearchange but I dont think its much better than the std.....
Chris
MarkCup
Ive had the 3rd to 4th or 4th to 3rd problem a few times too.
Having a play around with the gearbox I think its down to 3rd and 4th not being in line with each other...
1 3 5
|_/_|
2 4
Thats how my gearbox feels...once out of 4th, its not straight into 3rd, but off at a slight angle.
Anyone else have a wonky box like mine?
  VaVa
I have more trouble 2nd to 3rd tbh.... especially whn being a bit enthusiastic. i put it down to the driving position though. To get sat comfortably behind the wheel and farenough away from the pedals, I have to stretch to put the car in 3rd. Crunches like buggery.
I think I may also be trying to change too fast. If you think about it, you dont really need to change gear in micro second. asmoothe change is just as important.
