Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
My Gear leaver used to spring back to the middle when in the neutral position now it seems loose stays where ever it is left exept when moving it to the right then it springs back firmly to the middle. Any ideas whats causing this?
isnt there a spring (or 2) that pull against each other to hold the gear stick in neutral which ever way moved ? u can check this by getting under the car, that bit is visable, one prolly has broken or summat
